2004 vs 2005 ZX-10R
scn
2004 vs 2005 ZX-10R
Lugemata postitus Postitas scn »
Tere!
Öelge kuidas saaks 2004 ja 2005 Kawasaki ZX-10R-il vahet teha? VIN kood oleks ilmselt abiks? JKAZXT00CCA.... Tavaliselt peaks ju 10. täht seda näitama, antud juhul siis C, kuid mida ta siis näitab?:P
Teine küsimus oleks selline, et kas on normaalne et 1000cm3 baikidel tühikäik on selline ebaühtlane. Näiteks seesama eelpool toodud "identifitseerimist vajav" ZX-10R kippus tühikäigul nagu puterdama...? Pole varem selliste ratastega kokku puutunud ja mulle öeldi, et see olevat normaalne...
Ette tänades,
pets
mihkel99
Lugemata postitus Postitas mihkel99 »
Ratta dokumentides peaks see ju kirjas olema mis aasta oma on... :roll:
scn
unustasin mainida, et dokumente mul paraku käepärast ei ole...nii et see variant jääb ära.
manager2
Lugemata postitus Postitas manager2 »
leidsin sellise info Vini kohta...
Generally:
*The first three characters uniquely identify the manufacturer, make and type of vehicle.
*The second section consists of five characters (VIN positions 4 - 8) and identify the attributes of the vehicle. Different information is required for each type of vehicle.
*The third section consist of one character which is the check digit, calculated over the other 16 characters of the VIN. This character can be numeric or the letter X;
*The fourth section consists of eight characters on positions 10-17 of the VIN. The last five shall be numeric for cars, MPV's and light trucks and the last four shall be numeric for all other vehicles. The first character represents the vehicle model year, the second character represents the plant of manufacture. The third through eighth characters are a sequential production number (for manufacturers producing more than 500 vehicles per year). For other manufacturers, the sixth, seventh and eight position represent the sequential production number.
seega tagantpoolt loetuna 8-s number näitab väljalaskeaasta viimast numbrit.
loodetavasti on see info ka õige.
THESE FEW MINUTES ON THE TRACK… YOU LIVE MORE THAN SOME PEOPLE DURING THEIR LIFETIME
Tänatud: 118 korda
No põhimõtteliselt õige, aga seal ei pruugi olla number, võib täht ka olla.
A – 1980
B – 1981
C – 1982
D – 1983
E – 1984
F – 1985
G – 1986
H – 1987
I – not used
J – 1988
K – 1989
L – 1990
M – 1991
N – 1992
O – not used
P – 1993
Q – not used
R – 1994
S – 1995
T – 1996
U – not used
V – 1997
W – 1998
X – 1999
Y – 2000
Z – not used
Beginning with 2001, numbers are used to designate the model year.
1 – 2001
2 – 2002
3 – 2003
4 – 2004
Selle järgi C tähendab 1982 :-P
manager2
... ja veel, C täht peaks näitama 2012 aastat..... hmmm...
Code Year Code Year Code Year Code Year
A 1980 L 1990 Y 2000 A 2010
B 1981 M 1991 1 2001 B 2011
C 1982 N 1992 2 2002 C 2012
D 1983 P 1993 3 2003 D 2013
E 1984 R 1994 4 2004
F 1985 S 1995 5 2005
G 1986 T 1996 6 2006
H 1987 V 1997 7 2007
J 1988 W 1998 8 2008
K 1989 X 1999 9 2009
info siit: http://en.wikipedia.org/wiki/Vehicle_id ... r_encoding
tundub, et selle Viniga on sul mingid probleemid... ja kuna dokumente ka pole... peaksid vist sellest pillist eemale hoidma.
loonik
Lugemata postitus Postitas loonik »
Kawasakil on mingi oma ajarvamine neis VIN koodides. Kawa kohta "normaalne" tähistus ei kehti.
Kommionu ütleb selle ratta tootmiaasta VINi järgi sipsti ära. Edukat koodimurdmist.
Mis puutub tühikäiku, siis tehaseseades ei tohi ükski masin koliseda; möliseda ja longata vaid peaks kostma nagu Antsu viiul.
Viimati muutis loonik, 04 Dets 2006, 22:07, muudetud 2 korda kokku.
korke
s1000rr Guru
Tsikkel: roller
mis vahet on kas 2004 või 2005 ? ...üks ja sama ratas. :wack:
E-pood
HRQ
Tsikkel: Kawa KXF 250 MX / 450 SM
Lugemata postitus Postitas HRQ »
korke kirjutas:
Jopakolla Korkekene. Postitaja ju ei küsinud, mis neil ratastel vahet on vaid seda, kuidas erineva aasta ratastel VAHET TEHA.
Ning tehaseseades ei tohiks pöörded küll oluliselt kõikuda.
Viimati muutis HRQ, 04 Dets 2006, 22:27, muudetud 1 kord kokku.
Valmistan KROSSI NAASTREHVE ja JÄÄPIIKE
scn
ma tean jah, et sama, kuid väljalaskeaastat võiks ikka olla võimalik eristada. Ega ma jõudsin ise umbes samale järeldusele, et kas Kawal on mingi teine süsteem v on selle ratta VIN-iga midagi mäda ja siis nagu huvi suureneski...
CarPC
Lugemata postitus Postitas CarPC »
Kawasakil oma süsteem. Küll ja küll murdnud pead ja netist otsinud neid ja lõpuks ikka helistanud ARK'i tuttavale kes on asja järgi uurinud/vaadanud.
korke
s1000rr Guru
Tsikkel: roller
aga mida see sulle annab kui sa saad teada mis aasta oma ta on win koodi järgi ? ....passi läheb kirja esmaneregistreerimine nagunii...
aga teemasse.....pöörded jah ei tohiks eriti kõikuda.......
Äkki kaua seisnud tsikkel ja s**t bens sees .
HRQ kirjutas:
korke kirjutas:
E-pood
