Mida arvata Transalpi esihammaka kulumisest? (pilt)
Teema algataja - Postitusi: 274
- Tsikkel: used to be Blackbird
Re: Mida arvata Transalpi esihammaka kulumisest? (pilt)
Hunnev kirjutas:Minuarust see on ka täpselt nagu iga teine normaalne kulunud hammakas
pane kõik peale tagasi, nii nagu oli, tõsta pukipeale, mine taha ratta juurde tõmba ratas ringi ja vaata silmaga kas kett jookseb tagahammaka pealt otse ette hammakale ja siis nõnda ka tagumisele, kui jookseb, pole sul midagi häda, peale kulunud hammakate ja keti
Selles võib asi küll olla. Lugedes transalpi foorumit, siis seal räägitakse ka sellest
Poor chain alignment will cause a chain to wear prematurely. Don't rely on the marks on the swing arm to give you anything other than approximate alignment. Do a visual check from behind the rear sprocket to ensure the chain is running central and not favouring one side of the sprocket.
Yeah, I would check the alignment as others have stated. They make a neat little laser tool for this if you have a few buck to spare. Maybe run the chain with a bit more slack. I like to check it with rider's weight on it. Search this and the "show us your transalp mods" thread on ADV for problems with case wear at the final drive shaft. This has been discussed on T/A forums before. Running the chain too tight will cause premature wear on that output shaft housing, which is a far greater problem than needing a new chain.
Üks link ka taguratta seadistamisest
