DR750 ja DR800
Re: DR750 ja DR800
Vajan abi jet kit'i puudutavas küsimuses. Nimelt on mu Big SR42 mudelil Laser ProDuro http://www.dr-big-shop.de/shop/product_ ... cts_id=143 aftermarket summuti.
Ebayst karpade paranduskomplekte otsides leidsin sellise, päris paljudest osadest koosneva jet kiti,http://www.ebay.com/itm/Suzuki-DR800S-D ... 578wt_1163 mis väidetavalt peale aftermarket summuti paigaldamist lausa hädavajalik on: ( If you have installed an aftermarket, or modified the stock exhaust or intake, this is needed or you will damage your engine. Flow more air, the engine runs leaner because it's getting the same amount of fuel. Running lean causes detonation and hotter EGT's which ruin exhaust valves and destroy engines.) Vastupidiselt eelnevale on Hessleris jutt, et jet kit on antud summutiga vajalik ainult sr43 mudelile:http://www.dr-big-shop.de/shop/product_ ... cts_id=819 Oskab keegi öelda kui vajalikud või hoopis kasutud need jet kitid antud tsikli ja summuti puhul on?
