Head pakkumised: kraba kohe! → Soodsad varuosad CRF, KXF, RMZ, SXF, YZF !!!!
Seoses ekstreemvaruosad.ee tegevuse lõpetamisega, müüme laojääki ERITI SOODSATE HINDADEGA. Laos olevad Prox ja Wiseco tooed -45% jaehinnast. Kui mootoriremont juba tehtud, siis osta tulevikuks ette ära.
Toodete info ja tellimine - julgelt võtta ühendust 53 922 911
Toote kood toode kogus tk hind koos km
31.2423 ProX Camchain YZ450F '03-09 + WR450F '03-15 + YFZ450 '04-13 2 28.78 34.53
31.1403 ProX Camchain CRF450R'02-08 + CRF450X'05-15 + TRX450R'06-14 1 26.43 31.71
31.6427 ProX Camchain KTM450SX-F '07-12 + KTM505SX-F '08-09 2 28.78 34.53
31.2414 ProX Camchain YZ250F '14-16 + WR250F '15 3 23.48 28.18
31.1335 ProX Camchain CRF250R '04-09 + CRF250X '04-15 1 26.43 31.71
31.4409 ProX Camchain KX450F '09-16 + YZ450F '10-16 1 30.71 36.85
31.6328 ProX Camchain KTM250SX-F '09-12 + KTM250EXC-F '09-13 2 27.25 32.70
31.3407 ProX Camchain RM-Z450 '05-15 + RMX450Z '10-15 2 30.71 36.85
31.4406 ProX Camchain KX450F '06-08 + KLX450R '08-13 1 30.71 36.85
40.S475810 ProX Front Fork Seal and Wiper Set CRF250R'04-09 +450R '02-0 2 21.80 26.16
17.CS14053 ProX Clutch Spring Kit CRF450R '11-12 1 9.05 10.86
17.CS43017 ProX Clutch Spring Kit KX250F '05-16 + RM-Z250 '05-06 1 11.20 13.44
16.S13013 ProX Friction Plate Set CRF250R'04-07+'10 + KTM250SXF '06-12 2 34.43 41.31
16.S23049 ProX Friction Plate Set YZ250F '08-16 2 43.61 52.33
16.S24041 ProX Friction Plate Set YZ450F '07-13 + WR450F '05-15 2 35.87 43.05
16.S44028 ProX Friction Plate Set KX450F '06-09 1 39.46 47.36
16.S43027 ProX Friction Plate Set KX250F '06-16 1 43.02 51.62
16.S14016 ProX Steel Plate Set CRF450R '02-16 + TRX450R '04-14 1 27.33 32.80
16.S42015 ProX Friction Plate Set KX125 '97-08 1 38.55 46.26
16.S33032 ProX Friction Plate Set RM-Z250 '11-16 1 45.37 54.44
16.S14039 ProX Friction Plate Set CRF450R '11-16 1 35.94 43.12
16.S12006 ProX Friction Plate Set CR125 '00-07 + Gas Gas 125 '00-09 1 34.43 41.32
16.S53014 ProX Friction Plate Set KTM250/300/360/380SX-EXC '91-12 1 51.30 61.56
16.S13035 ProX Friction Plate Set CRF250R '08-09 +'11-16 + CRF250X 1 34.43 41.32
16.S53011 ProX Friction Plate Set KTM250SX-F '13-15+KTM350SX-F '12-15 1 40.51 48.61
16.S52001 ProX Friction Plate Set KTM125/144/150/200SX-EXC '98-16 2 30.13 36.15
16.S33028 ProX Friction Plate Set RM-Z250 '07-10 1 43.02 51.62
18.1413 ProX Inner Clutch Hub CRF450R '13-16 1 33.50 40.19
18.1411 ProX Inner Clutch Hub CRF450R '11-12 1 33.50 40.19
18.3341 ProX Inner Clutch Hub RM-Z250 '11-16 1 26.10 31.32
18.P1308 ProX Clutch Pressure Plate CRF250R '04-09+CRF250X '13-15 2 19.75 23.69
18.P4406 ProX Clutch Pressure Plate KX450F '06-09 + KFX450R '08-14 3 24.64 29.57
18.P4410 ProX Clutch Pressure Plate KX450F '10-16 1 19.75 23.69
18.1337 ProX Inner Clutch Hub CR125 '00-07 + CRF250R/X '04-09 + KTM2 1 22.42 26.91
18.1409 ProX Inner Clutch Hub CRF450R '09-10 1 27.32 32.79
18.P3408 ProX Clutch Pressure Plate RM-Z450 '08-16 + LT-R450 '08-11 1 23.72 28.47
34.1427 ProX Complete Gasket Set Honda CRF450R '07-08 1 74.37 89.24
34.1338 ProX Complete Gasket Set Honda CRF250R '08-09 1 64.33 77.20
34.1334 Prox Complete Gasket Set Honda CRF250R '04-07 CRF250X '04-13 1 64.34 77.21
34.1225 ProX Complete Gasket Set Honda CR125 '05-07 1 40.46 48.56
34.4406 ProX Complete Gasket Set KX450F '06-08 1 69.03 82.83
34.4336 ProX Complete Gasket Set KX250F '06-08 1 52.70 63.23
34.4339 ProX Complete Gasket Set KX250F '09-13 1 55.32 66.39
34.4223 ProX Complete Gasket Set Kawasaki KX125 '03-08 1 35.16 42.19
34.3409 ProX Complete Gasket Set Suzuki RM-Z450 '08-13 1 73.69 88.43
34.3341 ProX Complete Gasket Set Suzuki RM-Z250 '10-13 1 64.34 77.21
34.2426 ProX Complete Gasket Set Yamaha YZ450F '06-09 + WR450F '07-1 1 65.19 78.22
34.6427 ProX Complete Gasket Set KTM450SX-F '07-12 1 51.90 62.28
34.6326 ProX Complete Gasket Set KTM250SX-F '05-11 1 66.90 80.28
34.6019 ProX Complete Gasket Set KTM65SX '09-12 1 33.06 39.67
34.6018 ProX Complete Gasket Set KTM60SX '97-99 + KTM65SX '00-08 1 33.06 39.67
34.6011 ProX Complete Gasket Set KTM50SX '01-08 LC 1 16.68 20.01
35.1429 ProX Top End Gasket Set CRF450R '09-16 2 37.08 44.49
35.1225 ProX Top End Gasket Set CR125 '05-07 1 17.58 21.09
35.1325 ProX Top End Gasket Set CR250 '05-07 1 18.30 21.96
35.1338 ProX Top End Gasket Set Honda CRF250R '08-09 1 30.63 36.76
35.4223 Prox Top End Gasket Set Kawasaki KX125 03-05 1 18.23 21.88
35.1407 ProX Top End Gasket Set CRF450R '07-08 1 37.08 44.49
35.6011 ProX Top End Gasket Set KTM50SX '01-08 1 6.82 8.18
35.6012 ProX Top End Gasket Set KTM50SX '09-16 1 13.97 16.76
35.6018 ProX Top End Gasket Set KTM60SX '97-99 + KTM65SX '00-08 1 13.97 16.76
35.6019 ProX Top End Gasket Set KTM65SX '09-16 1 13.97 16.76
35.6222 ProX Top End Gasket Set KTM125SX-EXC '02-06 1 13.97 16.76
35.6326 ProX Top End Gasket Set KTM250SX-F '05-12 + 250EXC-F '07-13 1 32.24 38.68
35.6427 ProX Top End Gasket Set KTM450SX-F '07-12 1 34.27 41.12
35.6327 ProX Top End Gasket Set KTM250SX-EXC '07-16 1 17.18 20.61
35.6348 ProX Top End Gasket Set KTM300EXC '08-16 1 15.97 19.16
35.6227 ProX Top End Gasket Set KTM125SX-EXC '07-15+144/150SX '09-15 1 16.45 19.73
35.3409 ProX Top End Gasket Set RM-Z450 '08-16 2 30.63 36.76
35.3341 ProX Top End Gasket Set RM-Z250 '10-16 2 26.03 31.24
35.3337 ProX Top End Gasket Set RM-Z250 '07-09 1 24.67 29.60
35.2426 ProX Top End Gasket Set YZ450F '06-09 + WR450F '07-14 2 29.80 35.76
35.2440 ProX Top End Gasket Set YZ450F '10-13 2 30.63 36.76
35.2401 ProX Top End Gasket Set YZ250F '01-13 + WR250F '01-13 1 26.03 31.24
03.1212 ProX Con.Rod Kit CR125 '88-07 1 54.17 65.00
03.1402 ProX Con.Rod Kit CRF450R '02-08 1 85.13 102.16
03.4406 ProX Con.Rod Kit KX450F '06-08 1 79.04 94.84
03.4223 ProX Con.Rod Kit KX125 '03-08 1 54.17 65.00
03.6427 ProX Con.Rod Kit KTM450SX-F '07-12 + KTM450SX ATV '09-10 2 92.81 111.37
03.6326 ProX Con.Rod Kit KTM250SX-F '06-12 + KTM250EXC-F '07-13 1 71.45 85.74
03.6023 ProX Con.Rod Kit KTM65SX '03-08 1 45.35 54.42
03.6029 ProX Con.Rod Kit KTM65SX '09-16 1 45.35 54.42
03.3405 ProX Con.Rod Kit RM-Z450 '05-07 + RM-Z450 '13-16 1 79.04 94.85
03.3408 ProX Con.Rod Kit RM-Z450 '08-12 + RMX450Z '10-15 2 79.04 94.85
03.2426 ProX Con.Rod Kit YZ450F '06-09 + WR450F '07-11 1 79.04 94.84
03.4334 ProX Con.Rod Kit KX250F '04-09 + RM-Z250 '04-15 1 62.77 75.33
03.2414 ProX Con.Rod Kit YZ250F '14-15 1 71.45 85.74
24.110001 ProX Steering Bearing Kit YZ125/250 '96-16 +RM125/250 '91-92 1 19.15 22.98
39.160073 ProX Front Fork Bushing Kit KTM250/450SX-F '08-11 1 20.36 24.44
39.160020 ProX Front Fork Bushing Kit CRF250R '04-08 + CRF450R '02-08 1 13.27 15.93
39.160075 ProX Front Fork Bushing Kit KX450F '08-12 + CRF450R '09-13 1 20.36 24.44
39.160015 ProX Front Fork Bushing Kit KX250F '06-12 + RM-Z450 '05-12 1 20.36 24.44
39.160068 ProX Front Fork Bushing Kit YZ125/250/250F/450F '05-08 1 20.37 24.44
39.160082 ProX Front Fork Bushing Kit KTM150/250/300/350/450SX/F '12-1 1 21.31 25.58
37.910002 ProX Front Master Cylinder Rebuild Kit CR125/250/500 '99-07 5 8.84 10.61
37.910005 ProX Front Master Cylinder Rebuild Kit CRF250R/450R '07-13 1 8.84 10.61
37.910010 ProX Front Master Cylinder Rebuild Kit KX65 '00-13 2 8.84 10.61
37.910019 ProX Rear Master Cylinder Rebuild Kit YZ125/250 '03-13 4 8.84 10.61
37.910007 ProX Rear Master Cylinder Rebuild Kit CR125/250/500 '87-01 2 8.84 10.61
37.910009 ProX Rear Master Cylinder Rebuild Kit CRF150R '07-13 2 8.84 10.61
37.910008 ProX Rear Master Cylinder Rebuild Kit CR125/250 '02-07 3 8.84 10.61
37.910026 ProX Front Master Cylinder Rebuild Kit KTM125/250SX '09-13 1 8.84 10.61
37.63047 ProX Front Brake Caliper Rebuild Kit KTM125-505SX/SX-F'97-08 1 10.44 12.53
37.63032 ProX Rear Brake Caliper Rebuild Kit YZ125/250 '03-15 1 10.44 12.53
37.63029 ProX Rear Brake Caliper Rebuild Kit Honda CRF150-450 '02-15 1 10.44 12.53
37.63036 ProX Rear Brake Caliper Rebuild Kit RM-Z250 '08-13 1 10.44 12.53
37.63048 ProX Rear Brake Caliper Rebuild Kit KTM125-450SX/SX-F '03-15 1 10.44 12.53
37.63046 ProX Front Brake Caliper Rebuild Kit KTM125-450SX/SX-F'09-15 1 10.44 12.53
26.640016 ProX Countershaft Seal Kit KX125 '94-08 1 7.15 8.58
26.640009 ProX Countershaft Seal Kit CR125 '04-07 + CRF250R/X '04-16 1 6.72 8.06
26.640007 ProX Countershaft Seal Kit KTM60/65SX '98-08 1 7.86 9.43
26.710058 Prox wheel spacer kit - front suzuki RMZ250 07-14 RMZ450 05-14 1 15.54 18.65
26.710100 ProX Frontwheel Spacer Kit YZ125/250 '08-16 + YZ250F '07-13 1 8.43 10.11
26.710099 ProX Rearwheel Spacer Kit YZ250/450F '09-16 1 14.18 17.02
26.710073 ProX Frontwheel Spacer Kit WR426F '02 + WR450F '03-04 1 3.83 4.60
26.710031 ProX Frontwheel Spacer Kit KX250 '06-08 + KX250/450F '06-16 1 13.17 15.81
26.710042 ProX Rearwheel Spacer Kit KX125/250 '03-08 +KX250/450F'04-16 1 14.51 17.41
23.CBS42088 ProX Crankshaft Bearing & Seal Kit KX125 '88-08 1 23.39 28.06
23.CBS61097 ProX Crankshaft Bearing & Seal Kit KTM60SX '97-99+65SX 1 17.80 21.36
23.CBS61009 ProX Crankshaft Bearing & Seal Kit KTM65SX '09-16 1 18.85 22.62
23.CBS63006 ProX Crankshaft Bearing & Seal Kit KTM250SX-F '06-10 1 53.65 64.37
23.CBS33010 ProX Crankshaft Bearing & Seal Kit RM-Z250 10-16 2 49.31 59.17
23.CBS34008 ProX Crankshaft Bearing & Seal Kit RM-Z450 '08-16 2 55.02 66.03
23.CBS24001 ProX Crankshaft Bearing & Seal Kit YZ/WR250F '01-16 2 48.30 57.96
23.CBS33007 ProX Crankshaft Bearing & Seal Kit RM-Z250 '07-09 1 51.25 61.50
01.1325.A2 ProX Piston Kit CR250 '05-07 1 53.88 64.66
01.1413.B ProX Piston Kit CRF450R '13-16 12.5:1 1 78.44 94.12
01.1414.C ProX Piston Kit CRF450R '04-08 + CRF450X '05-15 12.0:1 1 78.44 94.12
01.4337.C ProX Piston Kit KX250F '06-09 13.5:1 1 66.90 80.28
01.4415.B ProX Piston Kit KX450F '15 12.8:1 1 78.44 94.12
01.6022.C Prox Piston Kit SX65 '00-08 1 22.91 27.50
01.6012.C ProX Piston Kit KTM50SX '01-08 + KTM50 Adventure '02-08 1 21.33 25.59
01.6324.B ProX Piston Kit KTM250SX '03-16 + KTM250EXC '06-16 1 62.27 74.72
01.6333.B ProX Piston Kit KTM250SX-F '13-15 + 250EXC-F '14-16 13.9:1 2 73.47 88.16
01.6338.B ProX Piston Kit KTM250SX-F '06-12 + KTM250EXC-F '07-13 "ART" 1 73.47 88.16
01.6338.C ProX Piston Kit KTM250SX-F '06-12 + KTM250EXC-F '07-13 "ART" 1 73.47 88.16
01.6427.C ProX Piston Kit KTM450SX-F '07-12 12.5:1 1 86.28 103.53
01.6433.B ProX Piston Kit KTM450SX-F '13-16 + KTM450SM-R '13-14 12.6:1 1 86.28 103.53
01.3338.C ProX Piston Kit RM-Z250 '07-09 "ART" 13.4:1 1 66.90 80.28
01.3408.B ProX Piston Kit RM-Z450 '08-12 12.2:1 + RMX450Z'10-15 11.6:1 1 78.44 94.12
01.3410.C ProX Piston Kit RM-Z450 '05-07 12.0:1 1 78.44 94.12
01.3413.B ProX Piston Kit RM-Z450 '13-16 12.5:1 1 78.44 94.12
01.3341.B ProX Piston Kit RM-Z250 '10-15 "ART" 13.4:1 1 66.90 80.28
01.3340.B ProX Piston Kit RM-Z250 '10-15 "ART" 13.4:1 1 66.90 80.28
01.2409.B ProX Piston Kit Yamaha YZ250F '08-11 13.5:1 1 73.47 88.16
01.2412.B ProX Piston Kit Yamaha YZ250F '12-13 13.5:1 1 73.47 88.16
01.2414.B ProX Piston Kit Yamaha YZ250F '14-15 + WR250F '15 13.5:1 1 73.47 88.16
01.2426.B ProX High Compression Piston Kit YZ450F '03-09 13.5:1 1 86.28 103.53
01.2429.C ProX Piston Kit YZ450F '03-09 + WR450F '03-15 12.5:1 1 78.44 94.12
01.2440.B ProX Piston Kit YZ450F '10-13 12.5:1 1 78.44 94.12
01.2444.B ProX Piston Kit YZ450F '14-16 12.5:1 2 78.44 94.12
01.4340.C ProX Piston Kit KX250F '10 13.2:1 1 66.90 80.28
01.1225.C ProX Piston Kit CR125 '05-07 1 45.58 54.70
01.1413.A ProX Piston Kit CRF450R '13-16 12.5:1 1 78.44 94.12
01.4124.B ProX Piston Kit KX85 '14-16 1 34.16 40.99
W4820M09600 Wiseco Piston Kit CRF450R '02-08 + CRF450X '05-15 12.0:1 1 90.39 108.47
W40089M09600 Wiseco Piston Kit Honda CRF450R '13-16 Std.12.5:1 1 90.39 108.47
W40003M07680 Wiseco Piston Kit Honda CRF250R '10-13 Dome 13.2:1 1 84.86 101.83
W4920M07700 Wiseco Piston Kit Kawasaki KX250F '07-09 (Coated Skirt) 1 84.86 101.83
W4980M09600 Wiseco Piston Kit Kawasaki KX450F '09-12 4V Dome 12.5:1 1 90.39 108.47
W868M05400 Wiseco Piston Kit KTM125SX '07-16 + Husqv. TC/TE125 '14-16 1 70.10 84.12
W40074M07800 Wiseco Piston Kit KTM250SX-F '13-15 + 250EXC-F '14-16 13.9:1 1 94.08 112.90
W4937M09700 Wiseco Piston Kit KTM450SX-F '07-12+XC-F '07-10 4V 12.5:1 FT 1 96.85 116.22
W874M03950 Wiseco Piston Kit KTM50SX '09-16 1555CS 1 40.58 48.70
W40073M09500 Wiseco Piston Kit KTM450SX-F '13-16 + FC450 '14-15 12.6:1 1 96.85 116.22
W40007M07700 Wiseco Piston Kit Suzuki RM-Z250 '10-16 13.4:1 1 84.86 101.83
W4921M07700 Wiseco Piston Kit Suzuki RMZ250 '07-09 13.4:1 1 84.86 101.83
W40086M09600 Wiseco Piston Kit Suzuki RM-Z450 '13-16 12.5:1 1 90.39 108.47
W4952M07700 Wiseco Piston Kit Yamaha YZ250F '08-11 5V 13.5:1 7700XU 1 87.63 105.15
W40111M09700 Wiseco Piston Kit Yamaha YZ450F '14-16 12.5:1 1 90.39 108.47
W40001M09700 Wiseco Piston Kit Yamaha YZ450F '10-13 4V Dish 12.5:1 1 90.39 108.47
W40072M07700 Wiseco Piston Kit Yamaha YZ250F '12-13 5V 13.5:1 1 87.63 105.15
W40116M07700 Wiseco Piston Yamaha YZ250F '14-15 + WR250F '15 13.5:1 1 87.63 105.15
W4953M09600 Wiseco Piston Kit Suzuki RMZ450 '08-12 12.2:1 1 90.39 108.47
07.FS13088-13 ProX Front Sprocket CR250 '88-07 + CRF450R/X '02-16 -13T- 1 6.45 7.74
07.FS62093-14 ProX Front Sprocket KTM125-530SX-EXC '91-16 -14T- 6 6.45 7.74
07.FS22005-13 ProX Front Sprocket YZ125 '05-16 + YZ/WR250F '01-16 -13T- 2 6.45 7.74
07.FS23099-13 ProX Front Sprocket YZ250 '99-16 + YZ/WR400/426/450F -13T- 2 6.45 7.74
07.FS12004-13 ProX Front Sprocket CR125 '04-07 + CRF250R/X '04-16 -13T- 2 6.45 7.74
07.FS43006-13 ProX Front Sprocket KX250F '06-16 -13T- 1 6.45 7.74
07.FS61004-13 ProX Front Sprocket KTM85SX '03-16 + TC85 '14-16 -13T- 1 6.45 7.74
07.RA62090-48 ProX Alloy Rear Sprocket KTM125-530SX/EXC '90-16 -48T- 1 18.46 22.16
07.RS62090-48 ProX Steel Rear Sprocket KTM125-530SX/EXC '90-16 -48T- 1 16.62 19.94
07.RA62090-50 ProX Alloy Rear Sprocket KTM125-530SX/EXC '90-16 -50T- 5 18.46 22.16
07.RS62090-49 Prox steel rear ktm 125-530 SX/EXC 49T 1 16.62 19.94
07.RS22099-49 ProX Steel Rear Sprocket YZ/WR250/400/426/450F '98-16 -49T- 1 16.62 19.94
